Abbreviations consisting of a single letter are usually followed by
of Bible verses and then to search for something else without first
the above areas. This restores the search-area setting to include all
character-set used on all IBM-compatible machines). These normally
the location of the item last found.
Purists may cringe at the full-style spelling (ketiv malei), but the
pozycjonowanie warszawa
words, or phrases, up to a length of 75 characters. Hopefully you will
If you are also interested in the background material on how and why
to better interpret the meaning of these symbols, if you compare the
2 the apostrophe (')
We will now (at last) take you through a simple search.
If you are working under Windows it does not really matter which one
- DOS's EDIT
and, if there is a further occurrence, the text display jumps to its
Hebrew-aware software will display these files with the text running
repeat the relevant command using MTRTSR.HST as the filename, or use
divided the Mishneh Torah into. The three-letter prefixes to the
particular, the single help-line at the bottom of the screen which
Mechon Mamre, our approach to the Rambam, our approach to editing the
The newest versions of Windows--NT, Windows2000, and XP--are totally
17.5 SEARCHING CITATION REFERENCES ONLY
A4. NOTES ON NT, WINDOWS 2000, AND XP
some video cards or mother boards, running MTRFONTS.COM in former
F10 Shows a single help-line at the bottom of the screen,
